I sold my BC6/DAB years ago, so I don`t exactly know, but as I remember, it won`t work.
1- you can test it pressing RADIO (DAB RADIO should start) and then AV - PC.
2- If I remember correctly - no. BC6-DAB is meant as a local source...(?) If you have a link system, try to activate DAB from another room by pressing RADIO (LINK _ RADIO?). BC6 should be set to V.OPT 2 (master).
3- Set one of your TVs to V.OPT 4. You will have to press LINK before you choose a source.
Hope this helps.
Stefan
