beovision 7-40 not reacting to audio command
This post has 5 Replies | 0 Followers
erandlux
Posts 116
erandlux Posted: Fri, Sep 20 2013 8:42 PM
hi guys,
since this evening, my beovision 7-40 is not responding to the audio command of the beo4
if I select TV or DVD, no probs, it works,. but if i select CD or N.Music, or A.AUX, it does nothing.
I have a beomaster 5 connected with masterlink , and since it is linked with CD, I cannot use it anymore.
the same with spottily and my beogram with a.aux.
any ideas on what it could be ?
Eric
olvisab
Posts 1,391
olvisab replied on Fri, Sep 20 2013 9:31 PM
Hi
You should unplug every unit and power them on again.
Sometimes this resolves the problem.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen
Flensborg, Denmark
Posts 14,680
Has someone maybe 'played' with the settings in the BS5?
AudioMaster: yes.
Option: 0.
erandlux
Posts 116
erandlux replied on Fri, Sep 20 2013 10:24 PM
I tried all this, nothing works.
It is like there is no connection anymore between beomaster and television.
The strangest is i cannot select CD, A.AUX OR A.MEM anymore on the beovision
I will go tomorrow to my dealer, it is my daughter's birthday and we definitively need music tomorrow
Eric
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Sep 21 2013 8:44 AM
Is it possible to access BS5 by pressing AV - N.MUSIC, ..N.RADIO.....?
What happens, when you press PC?
I'd try to reset the BV to V.OPT2 .
Hope this helps.
Stefan
erandlux
Posts 116
erandlux replied on Sat, Sep 21 2013 1:24 PM
After a few hours without power, i reset everything, and it works again, except the beolink active in the kitchen where the beolabs 4000 are connected. maybee the masterlink junction box, but it seems OK.
Strange things happen during the night here in Luxemburg.
Page 1 of 1 (6 items) | RSS
