hi guys,
since this evening, my beovision 7-40 is not responding to the audio command of the beo4
if I select TV or DVD, no probs, it works,. but if i select CD or N.Music, or A.AUX, it does nothing.
I have a beomaster 5 connected with masterlink , and since it is linked with CD, I cannot use it anymore.
the same with spottily and my beogram with a.aux.
any ideas on what it could be ?
Eric
Hi
You should unplug every unit and power them on again.
Sometimes this resolves the problem.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Has someone maybe 'played' with the settings in the BS5?
AudioMaster: yes.
Option: 0.
Is it possible to access BS5 by pressing AV - N.MUSIC, ..N.RADIO.....?
What happens, when you press PC?
I'd try to reset the BV to V.OPT2 .
Hope this helps.
Stefan
