Both worked on mine. According to the setup guide it supports options 0,1,2,5,6
tomap: Does the overture support option 5 and 6 ?
I suppose your ouverture is too old...
Ralf
As far as I remember, only the latest sw supports A.OPT 5/6, earlier ones just work with A.OPT 0 - 1 -2.
Maybe an update will help?
A.OPT 3 doesn`t exist, and A.OPT 4 (link option) is not supported.
Stefan
