Problem to set option 6 Beosound overture
Tom Arild Pedersen
Oslo
Posts 2
Tom Arild Pedersen Posted: Wed, Oct 9 2013 10:57 PM
Hi
I have a Beosound Overture that i want to set to option6, but it dosent to work. If i set it to option 1, 2, 3, or 4, I get a respons from the red led (it blink). If i try to set option 5 or 6 nothing is happening. Does the overture support option 5 and 6 ? If it is something wrong, i would all options to fail.
Regards
Tom
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Both worked on mine.  According to the setup guide it supports options 0,1,2,5,6
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Oct 10 2013 9:26 AM
tomap:
I suppose your ouverture is too old...
Ralf
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Oct 10 2013 12:32 PM
As far as I remember, only the latest sw supports A.OPT 5/6, earlier ones just work with A.OPT 0 - 1 -2.
Maybe an update will help?
A.OPT 3 doesn`t exist, and A.OPT 4 (link option) is not supported.
Stefan
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
