BEOVISION 7-55 ..... INSTALLATION ?
KRYS
Posts 5
KRYS Posted: Sun, Oct 13 2013 7:45 PM
Bonjour à toutes la communauté.
Je me retrouve seul pour installer un Beovision 7-55. Je suis donc preneur de conseil.
J'ai déballé la magnifique télé, (super lourd d'ailleurs) réussi à la poser sur son "Floor stand", mais maintenant il y a les pied métallique de transport à démonter, et la je ne trouve pas!!!
J'ai bien 2 clé allen, l'une pour les 2 vis du stand, et une autre que je supposais pour les 2  pieds métalliques, mais je ai trouvé aucune de vis de fixation .
Quelqu'un peut me venir à l'aide?
Merci.
CasperI
Posts 93
CasperI replied on Mon, Oct 14 2013 6:09 AM
Hi.
French is not what i'm best at, but if I (and google translate) understands your question correct, you need help to remove the service stands, that is mounted on the TV when it is delivered.
You won't find any screws, cause there are none.
All you got to do is pull the stands out. It may take some twisting and some force, but they will pop out eventually.
KRYS
Posts 5
KRYS replied on Mon, Oct 14 2013 10:46 AM
Hello Casperl,
Thank you for your reply. Yes that is exactly what it is the feet of service.
I admit to having a fear to take on it with force, I'm afraid of damaging my BEO ^ ^.
In addition I saw a plastic tab (should it break?)
http://www.casimages.com/img.php?i=131014114204438543.jpg
CasperI
Posts 93
CasperI replied on Mon, Oct 14 2013 11:01 AM
No worries, you won't damage anything. I've pulled out hundreds of those Smile
A firm push on front and rear side of the service stand at the same time should make it go loose.
BeoMegaMan
Posts 601
He's right...... one hand on the front side, the other on the back side and push straight down evenly. They'll pop right off and leave you wondering how the hell..........Smile
Ah, you know... A little B&O here, a little there
KRYS
Posts 5
KRYS replied on Tue, Oct 15 2013 4:24 PM
Merci à tous
Je reviendrais pour la suite de l'installation.
(Beomaster 5, satellite ...)
Thank at all for your informations.
I would return for the rest of the installation (boemaster 5, satellite .....)
didier
Posts 32
didier replied on Wed, Oct 23 2013 4:48 PM
Si vous etes en région parisienne je me ferai un plaisir de vous aider
KRYS
Posts 5
KRYS replied on Sat, Oct 26 2013 10:09 PM
Merci pour la proposition.
Je viendrais aux infos, pour faire évoluer le système (NAS, Apple TV, ... ??? )
Page 1 of 1 (8 items) | RSS
