Bonjour à toutes la communauté.
Je me retrouve seul pour installer un Beovision 7-55. Je suis donc preneur de conseil.
J'ai déballé la magnifique télé, (super lourd d'ailleurs) réussi à la poser sur son "Floor stand", mais maintenant il y a les pied métallique de transport à démonter, et la je ne trouve pas!!!
J'ai bien 2 clé allen, l'une pour les 2 vis du stand, et une autre que je supposais pour les 2 pieds métalliques, mais je ai trouvé aucune de vis de fixation .
Quelqu'un peut me venir à l'aide?
Merci.
Hi.
French is not what i'm best at, but if I (and google translate) understands your question correct, you need help to remove the service stands, that is mounted on the TV when it is delivered.
You won't find any screws, cause there are none.All you got to do is pull the stands out. It may take some twisting and some force, but they will pop out eventually.
Hello Casperl,
Thank you for your reply. Yes that is exactly what it is the feet of service.
I admit to having a fear to take on it with force, I'm afraid of damaging my BEO ^ ^.
In addition I saw a plastic tab (should it break?)
http://www.casimages.com/img.php?i=131014114204438543.jpg
No worries, you won't damage anything. I've pulled out hundreds of those
A firm push on front and rear side of the service stand at the same time should make it go loose.
He's right...... one hand on the front side, the other on the back side and push straight down evenly. They'll pop right off and leave you wondering how the hell..........
Ah, you know... A little B&O here, a little there
Merci à tous
Je reviendrais pour la suite de l'installation.
(Beomaster 5, satellite ...)
Thank at all for your informations.
I would return for the rest of the installation (boemaster 5, satellite .....)
Si vous etes en région parisienne je me ferai un plaisir de vous aider
