Hi, Firstly may I apologies for asking this question which must have been asked within the past but I just could find the answer.
I have just got a BeoCom 6000 mrk 1 with a separate pstn base (older style) which is great news as I will be getting a BeoCom 2 later to add on.
I thought the best way to start off would be to restore both units back to factory defaults so if any details had been left within the units then they would be gone and starting with a clean sheet shall we say.
I have managed to find out how to restore the BeoCom 6000 by simply pressing the red dot and then enter 7009 followed by “ok”
However I have searched and could not see anything on how to factory default the pstn unit, I know this can store up to 6 devices, but I am unaware of what is currently programmed.
Please advise how to do this,
Many thanks in advance
To reset the PSTN base follow the same procedure but use 7008. You need to reset the base first though as the handset needs to be registered to the PSTN to allow you to initiate the reset sequence.
Opman
Opman, thank you that worked a treat, base reset and handset and re registered no problems
Glad to be of help
