BeoCom 6000 mrk1 & BeoCom PSTN (older style)
This post has 4 Replies | 2 Followers
R19DAG
Posts 17
R19DAG Posted: Tue, Nov 19 2013 9:24 AM
Hi, Firstly may I apologies for asking this question which must have been asked within the past but I just could find the answer.
I have just got a BeoCom 6000 mrk 1 with a separate pstn base (older style) which is great news as I will be getting a BeoCom 2 later to add on.
I thought the best way to start off would be to restore both units back to factory defaults so if any details had been left within the units then they would be gone and starting with a clean sheet shall we say.
I have managed to find out how to restore the BeoCom 6000 by simply pressing the red dot and then enter 7009 followed by “ok”
However I have searched and could not see anything on how to factory default the pstn unit, I know this can store up to 6 devices, but I am unaware of what is currently programmed.
Please advise how to do this,
Many thanks in advance
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Nov 19 2013 9:34 AM
To reset the PSTN base follow the same procedure but use 7008. You need to reset the base first though as the handset needs to be registered to the PSTN to allow you to initiate the reset sequence.
Opman
R19DAG
Posts 17
R19DAG replied on Tue, Nov 19 2013 11:54 AM
Thank you I'll try it later
R19DAG
Posts 17
R19DAG replied on Fri, Nov 22 2013 10:03 PM
Opman, thank you that worked a treat, base reset and handset and re registered no problems
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Nov 23 2013 12:27 PM
Glad to be of help
Smile
Page 1 of 1 (5 items) | RSS
