Spotify Connect Now Live on A9
This post has 17 Replies | 1 Follower
BeoMegaMan
Posts 601
BeoMegaMan Posted: Wed, Nov 20 2013 5:51 PM
Go ahead and hit the BeoSetup App and apply the update to your A9! Just did ours in the shop and it worked flawlessly. Nice little gift for your A9 as we go into the holidays.
Ah, you know... A little B&O here, a little there
gysse2004
Hellerup
Posts 192
gysse2004 replied on Thu, Nov 21 2013 12:55 PM
This is good news, now we just need Beosound 5
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
BeoMegaMan
Posts 601
I don't understand? BeoSound 5 has had Spotify for months now.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Thu, Nov 21 2013 1:31 PM
Beosound 5 has Spotify, but not Spotify Connect- Big difference
Peter
w5bno123
London
Posts 578
w5bno123 replied on Thu, Nov 21 2013 1:59 PM
How long did the update take? Mine is still flashing red after 15mins!
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Nov 21 2013 2:04 PM
gysse2004:
+1.
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
BeoSound 5 is a 'lift your a** from the couch and go to the device' concept.
Why should the Connect version come to BS5?
Stick out tongueMMStick out tongue
Mikael
Denmark
Posts 179
Mikael replied on Thu, Nov 21 2013 3:17 PM
I didn't time it, but I'm sure mine took less than 15 mins.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
BeoMegaMan
Posts 601
Millemissen:
^^ What he said. The only thing Connect would offer the BS5 would be control of the content and remote volume from your portable device. A MLGW can take care of the volume remotely and select the next tracks. I can't imagine the option would come to BS5 that would allow for direct content control for Spotify to the BeoSound 5, but you never know. 3 years ago who would have that Spotify would be on the BS5 to begin with.
BeoMegaMan
Posts 601
w5bno123:
I didn't time it either, but it was less than 15 minutes. More like 5-8.
w5bno123
London
Posts 578
w5bno123 replied on Thu, Nov 21 2013 11:42 PM
After a reluctant power cycle (just in case I kill the A9) I reloaded the BeoSetup App, (ensure this is on 3.5.5) and the update took about 3 minutes.
Millemissen
Flensborg, Denmark
Posts 14,680
So - how does 'Connect' work on the A9?
What's the difference in daily use?
Mikael
Denmark
Posts 179
Mikael replied on Fri, Nov 22 2013 10:32 AM
There are both good and bad things about using Connect instead of Airplay.
The good:
The connection has been rock solid so far. No drop outs what so ever. (Not that this have been a big issue with Airplay after an upgrade of my wifi network)
The battery life of my iPhone is unaffected by music playback, which is really nice. Airplay can be quite battery intensive when used for several hours per day.
The bad:
Most of this have to do with the Spotify app. I haven't really had time to test it thoroughly yet, but it seems that after a period of time without contact between the App and the speaker, selecting playback of a new song  causes the sound to start playing from the iPhone and not the A9.
I have also experienced that the song/album art in the Spotify app doesn't match the song playing. Again this is when there haven't been contact between the to devices for some time, and a new song is selected on the iPhone.
Pressing the volume up/down buttons on the iPhone doesn't change the volume on the A9. This have do be done inside the Spotify App. This is properly the biggest disappointment compared to using Airplay. It's just inconvenient to open the App every time you need to change volume. This is the only thing on my "bad" list that can't be fixed by software updates. It's a natural limitation in iOS when the Spotify App is used like a remote instead of a music player.
w5bno123
London
Posts 578
w5bno123 replied on Sat, Nov 23 2013 12:14 AM
I have updated my A9 successfully and I am running Spotify Premium sw level 0.9.0 and I cannot seem to get Connect to work. What is the latest version of Sporify sw people are running?
BeoMegaMan
Posts 601
If all SW is up to speed try unplugging the router, idevice and A9, then restarting all. I had a client with similar issues that was cured that way.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Nov 23 2013 8:37 AM
Can someone confirm, that if you "seed" a playlist or a starmarked song, on your A9- then turn your Iphone off, the playlist will continiue to the end of that playlist. Or will it seed a new radio-playlist from the last song ?
Peter
w5bno123
London
Posts 578
w5bno123 replied on Sat, Nov 23 2013 9:21 AM
BeoMegaMan:
If all SW is up to speed try unplugging the router, idevice and A9, then restarting all. I had a client with similar issues that was cured that way. Ah, you know... A little B&O here, a little there
I will give this a go; when in doubt, pull the power out!
w5bno123
London
Posts 578
w5bno123 replied on Sat, Nov 23 2013 9:58 AM
A good old fashioned power cycle did the trick. Now my phone becomes a phone again when playing Spotify!
Page 1 of 1 (18 items) | RSS
