The 7-40 MK4 is the only 7 series I would look at this time. Or the 7-55 versions as they are still spectacular and keep up with the new series. The ZT60 is a great picture as well, especially if you plan on driving it with a BeoSystem. But as Martin says, there is more to it then just PQ..... Design, Movements, Sound, Integration, etc, etc.........
Ah, you know... A little B&O here, a little there
I have the previous year VT50 in a 65 inch size. While I haven't seen the Beocision you mention in quite a while, I never cease to be amazed and impressed by my Panasonics picture quality. It's the first set I've ever owned where I have felt no need to modify the factory picture settings. The THX Cinema and THX Bright Room settings are about as perfect as it gets. I imagine the ZT panel is even better.
Jeff
In terms of PQ, the major advantage of the Panasonic ZT60 is that it's calibration controls allow a full ISF calibration.
This review makes very interesting reading---awarded Reference Level.
http://www.hdtvtest.co.uk/news/panasonic-txp60zt65b-201305062961.htm
It should be borne in mind that Panasonic has announced that it will cease manufacturing Plasma TVs on the 31 March 2014.
If one wants a ZT60 one should act sooner rather than later.
