- Flere
smile and enjoy the moment
If it has a volume controlled pre out, then it's rather easy to tinker a cable yourself. I haven't seen such cable so far.
I've made them myself once for a friend with a Pioneer amplifer. It was actually a little box with on one side the RCA left and right socket and a 3,5mm jacket for the trigger signal. On the other side I made 2x powerlink. So he could connect his BL4000. Added a smal led for status et voilá.
Must be somewhere here on the dutch section,
THIS might be helpful
Ralf
