Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
I don't know of a source - but wish you good luck and hope you get an answer.
But just in case, I wanted to point out that a DIY (or some friend, local electrician) cable approach where you repurpose/rewire a more readily sourced cable type may be the way to go, so take a look at the BeoTech sister site:
http://www.beoworld.org/beotech/mcl3082a.htm
http://www.beoworld.org/beotech/wiring1.htm
http://www.beoworld.org/beotech/wiring2.htm
BeoNut since '75
PS - what length(s) are you looking for just in case someone has spares lying around
This cable is still available from B&O Dealers,but there has been a part No change,so they may say it's not available.You can make your own cables but the original is still neatest.
Nick
elephant:PS - what length(s) are you looking for just in case someone has spares lying around Beo-Ed :-)
solderon29:This cable is still available from B&O Dealers,but there has been a part No change,so they may say it's not available.You can make your own cables but the original is still neatest. Nick
The original part No for 100mtr drum was 6250113.You could also buy it in set lengths inc connectors.5mtre was 6270267 and 30mtr was 6270271.
Keying in these numbers will normally throw up the new numbers.
