MCL82 Cable
DMacri
United States
Posts 881
DMacri Posted: Wed, Apr 25 2012 1:09 AM
I have just purchased a couple more MCL82 2041 boxes to add to my system, but I need more wire to add them in. Can anyone recommend a source?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
elephant
AU
Posts 8,219
elephant replied on Wed, Apr 25 2012 1:48 AM
I don't know of a source - but wish you good luck and hope you get an answer.
But just in case, I wanted to point out that a DIY (or some friend, local electrician) cable approach where you repurpose/rewire a more readily sourced cable type may be the way to go, so take a look at the BeoTech sister site:
http://www.beoworld.org/beotech/mcl3082a.htm
http://www.beoworld.org/beotech/wiring1.htm
http://www.beoworld.org/beotech/wiring2.htm
BeoNut since '75
elephant
AU
Posts 8,219
PS - what length(s) are you looking for just in case someone has spares lying around
BeoNut since '75
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Wed, Apr 25 2012 10:12 AM
This cable is still available from B&O Dealers,but there has been a part No change,so they may say it's not available.You can make your own cables but the original is still neatest.
Nick
DMacri
United States
Posts 881
DMacri replied on Wed, Apr 25 2012 10:57 AM
elephant:
Beo-Ed :-)
Thanks - I probably should have mentioned that. I'll need about 30 feet of the cable if anyone has a spare length I can buy.
Dom
DMacri
United States
Posts 881
DMacri replied on Wed, Apr 25 2012 11:01 AM
solderon29:
Nick
Thanks, Nick. I'll give them a call. Do you know the new number? I just assumed that vintage wire would be gone by now.
Dom
solderon29
U.K.West Midlands
Posts 764
The original part No for 100mtr drum was 6250113.You could also buy it in set lengths inc connectors.5mtre was 6270267 and 30mtr was 6270271.
Keying in these numbers will normally throw up the new numbers.
Nick
DMacri
United States
Posts 881
DMacri replied on Fri, Apr 27 2012 11:28 PM
I called my dealer and they knew exactly what I needed and gave me a very fair quote in a per meter basis. I'm going to take the measurements and stop down ASAP. Thanks for the help.
Dom
Page 1 of 1 (8 items) | RSS
