Is there a list somewhere of the commands on a Beo 4 compared to 1000.
I have an LX5000 and on the 1000 you can turn the stand using picture and then left or right - cant work out how to do it on a Beo 4
Andrew
This was posted before:
Beo 4 Beolink1000 MkI & II Beolink 1000 MkIII & IV
[red] [SHIFT] [<] [SHIFT] [\/][blue] [SHIFT] [>] [SHIFT] [/\][green] [SHIFT] [<<] [SHIFT] [<<][yellow] [SHIFT] [>>] [SHIFT] [>>][MENU] [SHIFT] [TEXT] [MENU] [LIGHT] [SHIFT] [LINK] [LIGHT][GO] [PLAY] [PLAY][DTV] [SATELLITE] [SAT][DVD] [SHIFT] [CD] [SHIFT] [SAT][PC] [SHIFT] [STORE] [SHIFT] [STORE][DVD2] [SHIFT] [V.TAPE] [SHIFT] [V.TAPE] [V.AUX] [SHIFT] [TV] [SHIFT] [TV][A.AUX] [SHIFT] [RADIO] [SHIFT] [RADIO] [N.RADIO] [PHONO] [PHONO][N.MUSIC] [SHIFT] [A.TAPE] [SHIFT] [A.TAPE][FORMAT] [PICTURE] [PICTURE] [SPEAKER] [SOUND] [SOUND]
Beo 4 <> BeoLink 1000-------------------------------------
DVD/CDV = "SHIFT"+ "SAT"
V.AUX = "SHIFT"+"TV"
V-TAPE 2 = "SHIFT"+"V.TAPE"
A.AUX = "SHIFT"+"RADIO"
A-TAPE 2 = "SHIFT"+"A-TAPE" (older Systems) NETMUSIC = "SHIFT"+"A-TAPE" (newer Systems)
CD 2 = "SHIFT"+"CD"
PC = "SHIFT"+"STORE"
NETRADIO = "PHONO" (newer Systems)
Suggestion (I don't know if this command exists...):
You Need to add STAND or TURN (?) as a virtual button of your "LIST" (as described in the Beo4 manual).
- Press "STANDBY" (red dot button) and "LIST" simultaneously. (Beo4 display should display "ADD?" - if not - repeatedly press "LIST" till display is showing "ADD?") - Press "GO"- Press "LIST" until "STAND" is displayed. - Press "GO" - the Beo 4 should display "ADDED"
To select a function/source of your "LIST" - repeatedly press "LIST" until the desired function/source is displayed- press "GO" to send the command.
