Beolink 1000 and Beo 4 Commands
Andrew
Frinton, UK
Posts 917
Andrew Posted: Fri, Feb 14 2014 11:40 AM
Is there a list somewhere of the commands on a Beo 4 compared to 1000.
I have an LX5000 and on the 1000 you can turn the stand using picture and then left or right - cant work out how to do it on a Beo 4
Andrew
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 14 2014 12:03 PM
This was posted before:
Beo 4  Beolink1000 MkI & II  Beolink 1000 MkIII & IV
[red]  [SHIFT] [<]   [SHIFT] [\/]
[blue]  [SHIFT] [>]   [SHIFT] [/\]
[green]  [SHIFT] [<<]   [SHIFT] [<<]
[yellow] [SHIFT] [>>]   [SHIFT] [>>]
[MENU]  [SHIFT] [TEXT]   [MENU]
[LIGHT]  [SHIFT] [LINK]   [LIGHT]
[GO]  [PLAY]    [PLAY]
[DTV]  [SATELLITE]   [SAT]
[DVD]  [SHIFT] [CD]   [SHIFT] [SAT]
[PC]  [SHIFT] [STORE]   [SHIFT] [STORE]
[DVD2]  [SHIFT] [V.TAPE]  [SHIFT] [V.TAPE]
[V.AUX]  [SHIFT] [TV]   [SHIFT] [TV]
[A.AUX]  [SHIFT] [RADIO]   [SHIFT] [RADIO]
[N.RADIO] [PHONO]    [PHONO]
[N.MUSIC] [SHIFT] [A.TAPE]  [SHIFT] [A.TAPE]
[FORMAT] [PICTURE]   [PICTURE]
[SPEAKER] [SOUND]    [SOUND]
Beo 4         <>  BeoLink 1000
DVD/CDV     =  "SHIFT"+ "SAT"
V.AUX          =  "SHIFT"+"TV"
V-TAPE 2    =  "SHIFT"+"V.TAPE"
A.AUX         =  "SHIFT"+"RADIO"
A-TAPE 2    =  "SHIFT"+"A-TAPE" (older Systems)
NETMUSIC  =  "SHIFT"+"A-TAPE" (newer Systems)
CD 2          =  "SHIFT"+"CD"
PC             =  "SHIFT"+"STORE"
NETRADIO =   "PHONO" (newer Systems)
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 14 2014 12:05 PM
Suggestion (I don't know if this command exists...):
You Need to add STAND or TURN (?) as a virtual button of your "LIST" (as described in the Beo4 manual).
- Press "STANDBY" (red dot button) and "LIST" simultaneously.
  (Beo4 display should display "ADD?" - if not - repeatedly press "LIST" till display is showing "ADD?")
- Press "GO"
- Press "LIST" until "STAND" is displayed.
- Press "GO" - the Beo 4 should display "ADDED"
To select a function/source of your "LIST"
- repeatedly press "LIST" until the desired function/source is displayed
- press "GO" to send the command.
Page 1 of 1 (3 items) | RSS
