Beovision Avant power failure
This post has 7 Replies | 2 Followers
John
Stratford on Avon, UK
Posts 4
John Posted: Fri, Aug 23 2013 3:09 PM
I have an early BV Avant with VCR.
There is power to the TV at the end of the 2 pin power lead but the set is completely dead and does not respond to any of the Beo4 controls nor the selection of controls on the back of the set.
I think there may be an internal fuse to check but I do not know where this is located.
Can anyone help me.
Thanks.
Maurice
Posts 108
Maurice replied on Fri, Aug 23 2013 7:22 PM
Hi John
Firstly Check your plug fuse, I know this may sound obvious. Then is there the red standby light? When you press a command eg TV, VAUX, etc is there any responce from the set display eg does the red led turn to green for a brief moment or does it just stay red?
Regards Maurice
jandyt
Posts 13,111
jandyt replied on Fri, Aug 23 2013 9:13 PM
Also, sorry to state the obvious, but have you checked the hidden on/off button under the right hand corner of the screen?
kokomo
Spain
Posts 206
kokomo replied on Sat, Aug 24 2013 9:41 AM
jandyt:
Good point, although it may not be the answer in this case. When I had a BV3 I accidentally switched it off with this hidden button. Very relieved when I 'discovered' it!
John
Posts 4
John replied on Sat, Aug 24 2013 4:30 PM
Thanks so much.  Problem gone away much to my embarrassment.  I didn't even know the button was there and it must have been accidentally switched off when the TV was moved recently by an electrician.
jandyt
Posts 13,111
jandyt replied on Wed, Aug 28 2013 7:45 PM
Warm glowSmile
Stoobietoo
Exeter, Devon, UK
Posts 692
Don't you just love this forum? So many friendly helpful people and no-one judges you when they come up with a solution such as this. So many of us tend to panic when our prized B&O seems to go wrong, but everyone has a helpful suggestion and sometimes it really is as simple as a "hidden" button being pressed without you knowing. No one thinks you are foolish, they just love to help.
Well done guys, keep it up!
Stoobie
replied on Sat, Feb 15 2014 9:49 AM
I can't believe it, I have just had the same problem. I  didn't even know the red power button was there, our 2 year old must have turned it off.
Very, very relieved - Thanks (was just about to take it to the tip)
Page 1 of 1 (8 items) | RSS
