Dear all,
I have a problem with the Recording Timer of my BV11. If I select in the EPG a film that goes over midnight (e.g. 23:00 - 1:00) then the timer remains in the Timer index list and the BV11 still keeps writing [*REC] in the last line of EPG. It seems that he also still blocks the second tuner. I am having 2 DVB-S Signals.
Is there anyone with a similar problem or with a solution for this? The BV11 has the latest SW update.
Thanks, Heribert
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Just tried it on my BV11.
Red line appears as normal ( press red button once, then again to confirm a single recording). I haven't actually tried a recording across midnight so can't say whether or not the recording is OK.
Graham
The problem is exactly when the film goes over midnight. It also did not record this film...
the latest update of Feb. 27th seems to have fixed that problem.
