Timer Recording BV11 over midnight?
This post has 3 Replies | 2 Followers
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Tue, Feb 25 2014 2:29 PM
Dear all,
I have a problem with the Recording Timer of my BV11. If I select in the EPG a film that goes over midnight (e.g. 23:00 - 1:00) then the timer remains in the Timer index list and the BV11 still keeps writing [*REC] in the last line of  EPG. It seems that he also still blocks the second tuner. I am having 2 DVB-S Signals.
Is there anyone with a similar problem or with a solution for this? The BV11 has the latest SW update.
Thanks, Heribert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Tue, Feb 25 2014 6:41 PM
Just tried it on my BV11.
Red line appears as normal ( press red button once, then again to confirm a single recording).  I haven't actually tried a recording across midnight so can't say whether or not the recording is OK.
Graham
Heribert
Posts 804
Heribert replied on Wed, Feb 26 2014 6:19 AM
The problem is exactly when the film goes over midnight. It also did not record this film...
Heribert
Posts 804
Heribert replied on Fri, Feb 28 2014 3:44 PM
the latest update of Feb. 27th seems to have fixed that problem.
Page 1 of 1 (4 items) | RSS
