Beo5 and beo6 differances
This post has 2 Replies | 3 Followers
Mdjolly1973
Posts 51
Mdjolly1973 Posted: Sun, Oct 28 2012 8:52 PM
Hi guys
I hope i havent crossed over any previous posts regarding the main differances between the 5 and 6 ?
Im thinking about either purchasing a new beo6 or im sure ive read somewhere the 5 can be upgraded to a 6?!?
Confused.com!
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Mon, Oct 29 2012 9:38 AM
The Beo6 has a different screen which is slimmer and wider. It also has a wireless feature that allows two way connection to BeoSound5/BeoMaster5. This means that it can display cover art and track information.
The screens are no longer available for the Beo5's. If you drop a Beo5 and it needs repair, the only option is for the dealer to replace the ball & screen so it effectively comes back as a Beo6.
Opman
f5434964
Austria
Posts 206
f5434964 replied on Tue, Mar 11 2014 1:48 PM
Hello!
Is it really that easy? Changing the screen - and it's fine? My Beo5 needs a new battery; so why not doing an upgrade?
Best regards
Elmar
Page 1 of 1 (3 items) | RSS
