The Beo6 has a different screen which is slimmer and wider. It also has a wireless feature that allows two way connection to BeoSound5/BeoMaster5. This means that it can display cover art and track information.
The screens are no longer available for the Beo5's. If you drop a Beo5 and it needs repair, the only option is for the dealer to replace the ball & screen so it effectively comes back as a Beo6.
Opman
Hello!
Is it really that easy? Changing the screen - and it's fine? My Beo5 needs a new battery; so why not doing an upgrade?
Best regards
Elmar
