Hello all
I have a BV7 connected to a beocenter 9300 via a Convertor.
if I added a ML gateway would it be able to see the 9300 or can it only see new ML devices?
cheers all
Eclipse 65V1-32Beosound M5Essence MK2BLI
Your BC9300 should work with MLGW, assuming t is configured to A.OPT 0 and therefor controlled via your BV7.
Devices in option 0 don`t have to be assigned to MLGW, just add the audio sources RADIO, CD, A.MEM to MLGW webinterface for your main room and enable your BV7 to send/receive LIGHT and CONTROL commands via Masterlink if you add a home automation system.
Stefan
