Beocenter 9300
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Mar 8 2014 4:08 PM
Hello all
I have a BV7 connected to a beocenter 9300 via a Convertor.
if I added a ML gateway would it be able to see the 9300 or can it only see new ML devices?
cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Mar 9 2014 5:54 PM
Your BC9300 should work with MLGW, assuming t is configured to A.OPT 0 and therefor controlled via your BV7.
Devices in option 0 don`t have to be assigned to MLGW, just add the audio sources RADIO, CD, A.MEM to MLGW webinterface for your main room and enable your BV7 to send/receive LIGHT and CONTROL commands via Masterlink if you add a home automation system.
Stefan
Page 1 of 1 (2 items) | RSS
