LC2 don't react to touch
This post has 3 Replies | 0 Followers
bayerische
Ekenäs, Finland
Posts 4,770
bayerische Posted: Fri, Mar 28 2014 4:37 PM
Guys, I have 3 LC2's. None of them react to touch. Remote works fine.
I can't imagine that 3 LC2's different years would all quit work to the touch.
Is it a setting fault?
My old LC1 still works fine to the touch.
Too long to list....
Rivenflush
Gothenburg
Posts 333
The touch function wears off after a while - it is a known issue.
However, it can easily be fixed by retracing the "spider web" - have done it myself but now I cannot remember what the "paint" I have used is called - maybe "chrome lead" or something like that. Bought it on eBay for like 3 GBP.
There is no setting to deactivate the touch to my knowledge.
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Sun, Mar 30 2014 12:54 PM
Rivenflush:
Interesting, thanks. I'll try and google it.
Rivenflush
Gothenburg
Posts 333
This is what I used - even cheaper - 1.26 GBP from Hong Kong:
http://www.ebay.co.uk/itm/0-2ML-Silver-Conductive-Glue-Wire-Electrically-Paste-Paint-PCB-Trace-Repair-/390732070453?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item5af9723e35
One is enough for all three, and you probably only need to fill in the trace from the spiderweb to the base.
(before you begin you should also make sure that the touch is working by pressing the rubber tube with your finger - i.e. remove the black ball while the lamp is still connected)
Page 1 of 1 (4 items) | RSS
