Future home automation
This post has 23 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Apr 6 2014 7:50 AM
Hello all
i am currently running a control 4 system and have it controlling my bv7 via a lintronic -238
It is working really well but one day I think I would like to have it connected the way it was intended with a masterlink gateway.
as masterlink is disappearing these days what is the plan for home automation control of newer products with netlink?
one day I need to work out if it's better to update my tv rather than buy the ML gateway.
any thoughts?
cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
olvisab
Posts 1,391
olvisab replied on Sun, Apr 6 2014 11:34 AM
Hi
You could find a mlgw around 1000 euros on the second hand market if you are lucky enough, maybe less.
The problem is how will you use the mlgw with the control4 system. There is a mlgw driver for control4 sold by recluse av but I don't know the price actually.
Ii is sold only by control4 dealer.
If this driver is too expensiv maybe it doesn't worth to go this way.
If b&o sells a new mlgw it won't be cheaper, maybe easier to use or program.
In last february a new driver was published for another system so I conclude that the mlgw is still under development.
Br
Olivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Seanie_230
UK
Posts 2,278
Hi there
i have noticed on the bang and olufsen website you can now download control 4 drivers so maybe my dealer could use those with the MLGW.
my question is if new products are without masterlink and come with netlink then a MLGW will not do anything in the the future.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
The new MLGW is called the 'BeoLink GateWay' - and has already been announced at the ISE In Amsterdam february this year.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Apr 6 2014 12:07 PM
The question is how long it will take until 'Netlink' and 'Beolink Gateway' will offer ALL capabilities of 'Masterlink' and 'Masterlink Gateway'. I assume we'll have to wait many years...
Greets
Räuber
riverstyx
SouthWest UK
Posts 938
Raeuber:
From the press release and photos it appears the new Beolink gateway has a masterlink connection as well as netlink so it will be interesting to see more details when released.
Kind Regards,
Martin.
symmes
Posts 247
symmes replied on Sun, Apr 6 2014 2:13 PM
Seanie_230:
Hello all
any thoughts?
cheers all
My friend is running a B&O system with a US BV7 plus mac mini, BS900, 2 X BL3500, security, and cameras, from Control 4 and Gateway, with sets of codes the installer got from Control 4 for a small charge and B&O for no charge. Don't know the whole story but it can be done.
olvisab
Posts 1,391
olvisab replied on Sun, Apr 6 2014 2:34 PM
symmes:
"Sets of codes the installer got from control4" = should be the recluse av drive
The driver provided by b&o is not sufficient.
Please, could you ask your friend more details ? Drivers from control4 and price
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 6 2014 4:13 PM
I have heard the the nl gateway will arrive in may for resale.
I have been told it will be IP based, of course, and display up to date status on a Netlink tv.
Should make B & O extremely relevant in the home automation and could allow the bypass is control systems like crestron and amx
I currently use mlgw and the BO app as my complete home automation system to operate all radiora2.
The nl gateway will supposedly increase those functions and I understand will be mess expensive than the ml gateway.
Exciting times.
Seanie_230
UK
Posts 2,278
Hi there
cannot wait for more info, it does feel a bit strange the a netlink gateway will be needed when the new devices are already IP enabled.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
StUrrock
Posts 995
StUrrock replied on Sun, Apr 13 2014 8:53 PM
Seanie_230:
To operate a Bvis 7 from Conrol4 a Lintronic box is NOT necessarily required.
Just load the hex codes for B&O into the Control4 driver and then attach a wideband IR blaster to the C4 IR output, then hide (if you wish) the IR blaster within the Bvis 7.
For 2 way control you can have a PUC made up that will control the C4 processor from the Beo 4/5/6 or for massochists you can control the C4 directly from the Beo5/6.
This all works well for projects with a few B&O products within a Control4 enviroment. The PUC control from BeoVisions is such a brilliant feature and is vastly underused IMHO, and it could additionally benefit from having an additional IR passthrough option.
Of course if there are a lot of B&O main products in the project then of course the MLGW makes sense.
mjmedlo
Posts 922
mjmedlo replied on Mon, Apr 14 2014 12:08 AM
The NL gateway will give two way and allow control from an iDevice.
You don't have that now with the Ml gateway.
The ip system and cat7 apparently lend nicely to two way feedback.
I personally will be getting one.
I want to replace a bv10 with bv11 and add sys4 to a bv4 and connect the NL gateway to that and the legacy products I have so I'll have 2 way in specific areas.
Exciting stuff for B & O. I use lutron radio ra 2 and look forward to two way with lutron as well!
seanklemis:
Hi there
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
StUrrock
Posts 995
StUrrock replied on Mon, Apr 14 2014 7:11 AM
mjmedlo:
Again this will be great if you have a lot of B&O products to integrate with your lighting/automation system.
If however you only have a couple of products the NL gateway is not really necessary particularly as I hear that Cresron/C4/RTI are working on IP drivers for the current TV range.
mjmedlo
Posts 922
mjmedlo replied on Mon, Apr 14 2014 12:39 PM
I agree
I have 8 b&o televisions and 4 other link zones with the lighting system.
The gateway is the only way to go for me.
StUrrock:
StUrrock
Posts 995
StUrrock replied on Mon, Apr 14 2014 1:25 PM
mjmedlo:
I agree
 Without a doubt the best way Smile
mjmedlo
Posts 922
mjmedlo replied on Wed, Apr 16 2014 12:43 PM
I don't think it will be necessary to have the gateway rather it will be the new way to control the other automation products. Lights, curtains, etc.
It should be seen as a crestron, control 4, etc. alternative, not just a b&o interface.
I think all will be pleasantly surprised at the interaction. As I say, I think it will be a direct competitor for crestron and control 4 type systems. Much more than a box between the two.
STAY TUNED!!
olvisab
Posts 1,391
olvisab replied on Wed, Apr 16 2014 3:50 PM
mjmedlo:
keep on dreaming lol
StUrrock
Posts 995
StUrrock replied on Wed, Apr 16 2014 5:15 PM
mjmedlo:
That has to be the funniest line I have ever read on Beoworld, thanks for making me smile today.
mjmedlo
Posts 922
mjmedlo replied on Wed, Apr 16 2014 9:03 PM
Don't just leave me hanging on why I'm wrong.
Tell me why crestron and control 4 are so much better??
And... Help me justify the extra 50k to install a really good control system with your expertise in the matter.
StUrrock
Posts 995
StUrrock replied on Wed, Apr 16 2014 9:39 PM
mjmedlo:
Thank you for the second post I found so funny on BeoWorld.
To put it bluntly the MLGW is a sort of lintronic box. Do not get me wrong lintronic is brilliant and the MLGW does it's job ok.
To compare Crestron to Control4 is like comparing champagne to cava.
MLGW and the new B&O offering is merely an interface from B&O to other systems, in it itself it is nowadays virtually useless unless your system includes a lot of legacy ml products.
As mentioned before with IP drivers to control B&O TVs other control systems do not need a B&O interface box.
With no sensible Multiroom audio solution from B&O at present why buy a MLGW or equivilant?
mjmedlo
Posts 922
mjmedlo replied on Wed, Apr 16 2014 10:34 PM
Certainly to each their own.
I have found the beolink app to be MUCH more than a lintronic box.
I use the beolink app as whole home control with every lighting zone individually programmed and all scenes programmed through the lutron system.
Personally I find the beo4 much nicer than a control 4 app and frankly the control 4 app is clunky.
The only automation system IMO worth paying for is one which has an overlay of the room where one can press the light or audio/video device they want to initiate. That only comes with about $50k of programming and equipment here in the good ole US of A.
As I said, to each their own. For me, the mlgw and beolink gateway more than provide the automation I'm looking for.
I use lutron and B&O independently and concurrently for scene triggers.
Couldn't be happier with mine. .... And I have the $50k to add to my B&O collection.
If you find the control system to be worth the extra added cost then so be it.
I think the mlgw is much more powerful and has much more potential than most users want or need. I expect the BeolinkGW will follow and surpass my current uses.
StUrrock
Posts 995
StUrrock replied on Thu, Apr 17 2014 6:31 AM
mjmedlo:
Control4s interface is not to everyone's taste but as a system it's capabilities are far more than the MLGW you are right my comment re lintronic was a bit tongue in cheek ;)
I fail to see where this figure of £50k comes from unless your using savant/amx/Crestron. In our jobs the majority of the spend is on the music system and lighting just like in yours.
We have and continue to get the MLGW to talk to any system that will accept rs232 or IP commands, but in most recent instances our clients want a universal remote/app/keypads to work throughout their home.
If there isn't a B&O product in the majority of rooms the MLGW just adds to the complexity and cost of programming for no added benefit.
Really glad you enjoy your system for your needs we would have specified a MLGW but that scenario is becoming rarer and rarer in our automation projects.
We think of the MLGW as a B&O control system that controls other control systems, which in turn can be controlled itself by other control systems. :)
BeoMegaMan
Posts 601
StUrrock:
mjmedlo:
I have a feeling everyone will be blown away shortly.
Ah, you know... A little B&O here, a little there
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sat, Apr 19 2014 10:04 AM
mjmedlo:
STAY TUNED!!
Hi there all
I am really interested to hear what the new NL device will bring. I do really miss my beo4 and an not 100% sure the move away was right.
I decided to always keep my bang and olufsen in my living room. I think I will have a look at a different approach currently I have control 4 controlling the bang and olufsen I may look into using bang and olufsen to control the rest of the house via control 4.
exciting times
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (24 items) | RSS
