The red lamp on my Beolit 12 never turns green.
It does not take any charging as it seems. Is there a possibility to swap battery? Its a second life Beolit 12, but its probably under warranty.
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
You can check the charge of the battery through the setup page (either using the setup app, or through a browser).
You can check whether the percentage is or is not increasing. If still under warranty, don't hesitate and check with a dealer.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Hiort:The red lamp on my Beolit 12 never turns green. It does not take any charging as it seems. Is there a possibility to swap battery? Its a second life Beolit 12, but its probably under warranty. /C Happy owner of: BV10 40", 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11, Playmaker, Beolab 3500 1:st prize winner Beoworld January Price Draw 2011 (BL8000).
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hiort:The red lamp on my Beolit 12 never turns green.It does not take any charging as it seems. Is there a possibility to swap battery? Its a second life Beolit 12, but its probably under warranty./CHappy owner of: BV10 40", 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11, Playmaker, Beolab 35001:st prize winner Beoworld January Price Draw 2011 (BL8000).
Problem:
Could not charge the Beolit 12. Charging lamp stayed red, and the BeoSetup said 0% charge. With no mains cord connected the Beolit stayed dead.
Solution:
I made a reset back to factory setting.
Now I can see that the battery is charging on the BeoSetup App.
Problem sorted :)
