Batteryproblem with Beolit 12
Hiort
Sweden
Posts 2,895
Hiort Posted: Tue, Apr 15 2014 9:22 PM
The red lamp on my Beolit 12 never turns green.
It does not take any charging as it seems. Is there a possibility to swap battery? Its a second life Beolit 12, but its probably under warranty.
/C
crossbytje
Posts 224
You can check the charge of the battery through the setup page (either using the setup app, or through a browser).
You can check whether the percentage is or is not increasing. If still under warranty, don't hesitate and check with a dealer.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Michael
Sweden
Posts 2,578
Michael replied on Wed, Apr 16 2014 6:42 PM
Hiort:
/C
Happy owner of: BV10 40", 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11, Playmaker, Beolab 3500
1:st prize winner Beoworld January Price Draw 2011 (BL8000).
The battery is easily replaced by B&O. It looks like a small laptop battery but with a cable that attaches to the beolit with a screw to hold it.
StUrrock
Posts 995
StUrrock replied on Wed, Apr 16 2014 7:43 PM
Hiort:
/C
If it's under warranty you can go to the BeoPlay website to arrange to get it collected/sorted.
The service is very good.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Apr 22 2014 8:36 AM
Problem:
Could not charge the Beolit 12. Charging lamp stayed red, and the BeoSetup said 0% charge. With no mains cord connected the Beolit stayed dead.
Solution:
I made a reset back to factory setting.
Now I can see that the battery is charging on the BeoSetup App.
Problem sorted :)
Page 1 of 1 (5 items) | RSS
