Hi
I have just made some changes in my master link wire ring and now the Beolab 3500 is not turning on every time i try. It also turns off by it self sometimes. Does anyone knows which of the color wires that controls the on/off signal?
Mogens
Be more specific about the changes you have been done on your ML link, here you find the colour codes : http://www.beoworld.org/beotech/misc1.htm
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Adding and splitting via junktionboxes. I was wondering if there could be a loose connection in the junctionbox.
It depends how crowded your junction box is. You have two choices, redo the whole box or strip/twist/solder the lot using heat on shrinkies for insulation.
