Link wirering
This post has 3 Replies | 0 Followers
Bundy
Posts 67
Bundy Posted: Sat, May 17 2014 11:39 AM
Hi
I have just made some changes in my master link wire ring  and now the Beolab 3500 is not turning on  every time i try. It also turns off by it self sometimes. Does anyone knows which of the color wires that controls the on/off signal?
Mogens
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, May 17 2014 4:39 PM
Be more specific about the changes you have been done on your ML link, here you find the colour codes : http://www.beoworld.org/beotech/misc1.htm
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Bundy
Posts 67
Bundy replied on Mon, May 19 2014 6:53 AM
Adding and splitting via junktionboxes. I was wondering if there could be a loose connection in the junctionbox.
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Mon, May 19 2014 7:02 AM
It depends how crowded your junction box is. You have two choices, redo the whole box or strip/twist/solder the lot using heat on shrinkies for insulation.
Page 1 of 1 (4 items) | RSS
