Can anyone shed light on the best version/revision ATV to buy for my recently acquired BV9 Mark I? The dealer has recommended an earlier 720p (second generation I believe) ATV but the later model also supports 720p as well as 1080p so curious as to why a second generation model would be better?
Thanks... Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Go for the 3rd Gen. - HD (1080) Content runs smooth.
The only advantage of the 2nd Gen. is imho the jailbreak ability. (we sold our 2nd Gen).
Thanks. Do you have a BV9 with the ATV?
I'm sure microsuck will have a product to placate you
