Hi everyone,
I would like to know if the BEOVISION AVANT 55 is compatible with SRT subtitles files for viewing videos via the HOME MEDIA feature (through DLNA or with a USB drive) ?
I watch a lot of movies & TV shows and I need to have the subtitles on the TV (I'm french!)
Thnaks
Fred
Radiomekaniker:Hi the TV support embedded srt subtitles I.e. not a separate srt file. Some times it is necessary to step forward and backward to get the subs working (I hope that bug will be fixed).
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Radiomekaniker:1 start play back 2 Menu + 5 (select the subs) 3 step forward and then back so you won't miss anything (1 minutes steps) then the subs should show up.
