Like to know how to adjust the droppoint. Noticed this is rather to the edge of the record rim on records. And sometimes it is falling from the record.
http://beocentral.com/beogram6000-1980s
nobody here????
Hi there.
I will try to help you. On this model - take off the platter, then take off the Black plastic disc - and then you will see this:
You can then adjust on the two screws A and B. A for 17cm records (singles) -and B for 30 cm's (Lp's).
Hope this helps you.
Steffen
thanks for sorting this out will try this.
