Adjust the point to drop the tone arm on radial Beogram
This post has 3 Replies | 0 Followers
Toine1
Posts 45
Toine1 Posted: Fri, Jun 13 2014 8:46 PM
Like to know how to adjust the droppoint. Noticed this is rather to the edge of the record rim on records. And sometimes it is falling from the record.
http://beocentral.com/beogram6000-1980s
Toine1
Posts 45
Toine1 replied on Sun, Jun 22 2014 7:57 PM
nobody here????
Steffen
Denmark
Posts 1,408
Steffen replied on Sun, Jun 22 2014 9:14 PM
Hi there.
I will try to help you. On this model - take off the platter, then take off the Black plastic disc - and then you will see this:
You can then adjust on the two screws A and B.
A for 17cm records (singles) -and B for 30 cm's (Lp's).
Hope this helps you.
Steffen
Toine1
Posts 45
Toine1 replied on Thu, Jun 26 2014 5:52 PM
thanks for sorting this out will try this.
Page 1 of 1 (4 items) | RSS
