MCL2AV: Programming guide
Aleksei
Estonia
Posts 22
Aleksei Posted: Fri, Apr 27 2012 6:52 PM
Dear colleagues,
I would like to ask your assistance.
I bought MCL2AV type 2031 with MCL transceiver. My problem is that i have no manual for this units and can't correctly program it.
After I plug the main adapter, I hear, that speaker relay switch on and then off.
First of all  I set it up to option 2 (st-by - LINK - 2 - store). The MUTE LED bliks ones.
After that I programmed it to line out (st-by - TIMER (hold on transceiver) + AV (on BEOLINK 1000)
After that MCL2AV does not wake up, when I pressed to CD or A.TAPE buttons on BEOLINK 1000. I tried with and without LINK button.
Only after replug main power adapter I can operate with MCL2AV.
Is this normal reaction or something is wrong with my MCL2AV?
Thank you in advance,
Aleksei
Aleksei
Page 1 of 1 (1 items) | RSS
