Hi I have a mx6000 28" tv motorised floor stand , will this be suitable to hold a mx4000 21" tv or where the satnds all different sizes ?
Sadly no - the MX4000 would control it OK but the stand itself is too big - and specifically the mounting plate is different. Certainly my MX4000 will not attach to my MX5500 (28inch) stand. You could possibly change the mounting plate - and I think one from a non-motorised MX4000 stand would work.
Even if the mounting plates were interchangeable, the end result would look totally silly. The horizontal floor bar of a 28" MX stand is 10 cm wider than a 21" MX TV!
--mika
Thanks Guys !
Thanks thought as much !!
