Using Beosound 9000 with other equipment
This post has 11 Replies | 0 Followers
Jkolpen
Posts 6
Jkolpen Posted: Thu, Apr 3 2014 12:18 AM
Hello.  I am new to the site.   I have a Beosound 9000 which I would like to use as a CD source with a Marantz AV 8801 sound processor, which drives a Rotel amp and B&W 803 speakers.   What is the best way to accomplish this connection?  Thanks for the help
BeoMegaMan
Posts 601
A digital coax cable.
Ah, you know... A little B&O here, a little there
Jkolpen
Posts 6
Jkolpen replied on Thu, Apr 3 2014 10:54 AM
What about a pliable to RCA?
Millemissen
Flensborg, Denmark
Posts 14,680
A dig-coax cable connection would be cheaper and better than some 'analog adapter thing'.
Jkolpen
Posts 6
Jkolpen replied on Thu, Apr 3 2014 12:04 PM
I meant power link to RCA cable
Millemissen
Flensborg, Denmark
Posts 14,680
That was what I meant too!
Try both ways - choose the best.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Apr 3 2014 3:50 PM
One way of course is to use the RCA SPDIF digital out directly to the digital in of the processor. That will get you the CD output, but not of course the radio or any other source.
The other way is to get a DIN to 4 RCA plug converter/cable and hook not to the PowerLink but to the Aux In jack on the BS9000. It is a traditional tape in and out layout, two fixed level outputs, L and R, and two inputs, L and R. I've used this in my last setup to take aux in from other sources, and give me line outs that I connected to an integrated amp that I used to drive passive speakers throughout my house. Now I use Masterlinked Beolabs around the new house.The amp took standard RCA inputs so I used a DIN to RCA converter cable.
Jeff
Millemissen
Flensborg, Denmark
Posts 14,680
Off course Jeff is right!
But the in the op the question was "I would like to use as a CD source" - that is why I went for the dig-out.
Jkolpen
Posts 6
Jkolpen replied on Thu, Apr 3 2014 4:24 PM
 Thank you much.  I don't need the other sources in the Beosound 9000 so I like the digital output idea.  I am not familar with the cable you suggest.  Would  you plese describe that cable in more detail and possibly suggest a source to purchase it.  Thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
Something like this:
Jkolpen
Posts 6
Jkolpen replied on Thu, Apr 3 2014 6:17 PM
Thanks Much.
WalkingPossession
Manchester
Posts 360
buy it from Steve @ Sounds Heavenly
see the blue advertisement at the bottom of the page.
Michael
Page 1 of 1 (12 items) | RSS
