I've just used a very soft, new cloth and an anti-static furniture polish to good effect. Someone must have a user manual with the B&O recommendation.
Dave
Yes,I looked at the user manual after I'd replied and it says nothing. The first time you clean it, it may look patchy but it does get better if you apply the polish lightly and evenly - don't rub hard or you'll get dull patches. If it's not been cleaned before it may be quite grimey. I had to do mine as one of the cats curls up and sleeps in the top!
hope it works out.
Dave.
I had a white one. It has a plastic finish and I once used a detergent (diluted Mr. Clean) to clean it. I then applied a light coat of furniture (actually multi-surface) polish.
Cleve - read your query about the Cona. I have used a various range of polishes especially on antique wooden finishes - this polish brings all wood up to a beautiful shine - called LIQUID GOLD, however, for cleaning materials especially odd materials, such as, tapestry, brocade, and stretch nylon finishes you can buy a product from LAKELAND or DUNELM MILL that will clean material without leaving it blotchy or discolour any part of it. The name of the product escapes me at the minute, but if you ask some of the customer service can point you in the right direction. The product you spray onto a dry cloth and just rub over in light sweeping motion - the dirt, grime just comes off. Hope that this will assist you. David
Professor David A Flynn JP LM
Cleve - tell me about it. I think that this BEOVIRUS has already infected me. I really can't believe how stupid I was to leave this Beocenter 2200 in the loft for such a long time. My nephew is responsible as he was up noising about and discovered it. Then of course, I thought that it wouldn't work and ended up buying the 4000 system from Ebay - that I am totally chuffed about - I have sound now coming from the drawing room and the living room - not at all the one time of course, but it could happen.
Thanks for your advice and support much appreciated.
David
Cleve
Lakeland do a product that will clean a range of materials including plastic and would you believe it bakelite. I was over this afternoon and the customer service manager said that they have a range of products that would suit you.
I know this is an old thread but since it is related I thought I would ask here, hope this is okay!
Hopefully I will be receiving a white cona soon. Apparently it is scratched and a little discoloured. This doesn't bother me too much as it will be living under my bed which I'm hoping the girlfriend will enjoy and make my CX100s look like they are amazing for their size if I keep the subwoofer a secret to the B&O naysayers (mad people)!
Is there a way to restore the plastic on the enclosure? Or does anyone know what type of plastic the cona is made from? Which would help me to find the appropriate product!
You know how we are though. If it can be improved, it will be!
Cheers for any help
Chris
The Cona shell is made of the same black resin that was used as the chassis, frame or front baffle in many B&O speakers of the same era, and then painted black or white. So you would not be restoring the plastic, but the paint. Not sure if that helps!
--mika
Thankyou that helps enormously!
I can probably deal with the paint in a similar way to a car with any luck. Test an inconspicuous area first and all!
