Beovision 5 - 'WAIT' Message
This post has 2 Replies | 2 Followers
MOLE
Posts 6
MOLE Posted: Sat, Apr 5 2014 8:54 PM
Hello All
I have just acquired a Beovision 5. After I switched it on it asked me for a PIN which I stupidly tried to guess (1234, 1111, 0000, etc). I now have what I believe to be the correct code which I got by giving my serial number from the back of the set to my local dealer (Bournemouth, UK).
When I now switch the Beovision on (by pressing TV on the remote) all I get on the screen is 'WAIT' at the top of the screen. No mater what I press on the remote it just says 'WAIT'. If I leave it for more than a minute or so the set switches itself of.
I have unplugged it from the mains and left it for well over 3 hours (as per the instruction manual) and I still get the same issue. I just can't get back to a point where I can input the PIN. I can't find anything in the manual regarding the 'WAIT' message. I would leave it on for a few hours but, as I said, it switches itself off.
Has anyone come across this issue and does anyone have the answer? Thanks in advance for your help.
Tayne
Posts 38
Tayne replied on Sat, Apr 5 2014 8:58 PM
The television has to be connected to power and left for 3 hours before it will request a PIN code. If a button is pressed it will restart the count for another 3 hours.
This does not work if the television is disconnected from the mains.
Just leave it plugged in overnight and you will be ok in the morning.
MOLE
Posts 6
MOLE replied on Sat, Apr 5 2014 9:12 PM
Thanks. I'll leave it on over night and have a look in the morning.
Page 1 of 1 (3 items) | RSS
