The wireless range of speakers I am guessing have no two way communication unlike a masterlink system?
With masterlink I can go into the link room switch on and operate the main system via my remotes, I am guessing this can't be done in a link room with a wireless speaker system using a transmitter 1 and receiver 1 setup.
If this is the case it is a step back in my opinion, I hope to be proved wrong.
IWS (WISA/the B&O way) is 'wireless PowerLink' and has nothing to do with MasterLink.
As i suspected MM, a pity. I was disappointed when i couldn't select a different source in the masterlink second room with BS5 which you could with the BS4. I frequently had radio on in a link room and N.Music in the main.
