i download the user guide of the Beosound5 ENCORE and i dont' see how control bass-treeble-balance..they are control or not ?thank you.
Hi Archie,
Yes they can be controlled, below are the instructions from the guide:
Best
Paul
Use the pointer to highlight MODE. > Turn the
> Turn the
.> Use the pointer to highlight SOUND. > Turn the wheel to select the sound element you wish to adjust; VOLUME, GO
BALANCE, BASS, TREBLE or LOUDNESS and press
The current value is the‘wheel focus’ upon entry. > Turn the wheel wheel wheel to adjust the sound setting and press GO to store the setting
Ok,
in fact, they are 2 manuals to download, and i download the start manual not the full.
thank you.
