I've got a Beoplay V1 that I use to listen to Airplay streaming through an Apple TV. The Apple TV is configured to the DVD button, as I haven't gotten around to get my BEO4 update yet.
So far I figured out to:
So far so good, but is there anyway to automate this process, and avoid a few of the button presses? I guess, what I want is something like an A.DVD button?
Best regards, and thanks :)
I posted a similar question ages ago and I don't think there was a way - if there is then I would love to know too!
I've read this thread on the subject as well:
http://archivedforum2.beoworld.org/forums/p/1875/15947.aspx
But it didn't seem to offer a fix :/
It's not a big deal because I've got P.MUTE and SPEAKER GROUP shortcuts on LIST, but it would be really sweet to turn it on with 1 click.
No, it is not a big deal - 'a big deal' is different!
But explaining this to my wife and to friends (to whom I always say, that controlling a BV is troublefree) is a big deal.
On the other hand iit should not be 'a big deal' for B&O to make a fix to this.
On the newest Beo4 there is an entry (in List) called 'A-APPLE', so maybe they already have thought of the need for turning on a BSys4-based system in 'Audio only' mode.
Maybe coming in a next update, is my guess.
As for the possibility to choose which source to turn on in which speakers constallation, it should not be that difficult - and I really wonder why they did not already have made this possible.
A simple entry in the source setup menu, that lets you choose a default 'speakers group' for a specific source, would solve that problem!
Maybe we will also see that in a future update - still hoping
Ah, you know... A little B&O here, a little there
BeoMegaMan:Get a NL converter.
Pretty heavy solution just to play music on a V1 via AirPlay with less button-pushes on the Beo4
Out of curiosity, what is an update for the Beo4?
I assume a dealer supplied update to the software running on the remote?
Many thanks..
John... :-)
Neither you nor the dealer can update a Beo4.
My advice would be to let an 'older' Beo4 upgrade with a new PCB and new 'keyboard'.
This way you will get the newest SW - and a Beo4 fit for the new generation B&O tv's.
