Master Link Connection Question
This post has 8 Replies | 0 Followers
striker27
Posts 64
striker27 Posted: Sun, Apr 13 2014 6:31 PM
I have at present a Beosound 4000 connected to 3 1658 Passive amps in various areas of the house operated through the Ir eye.....  Everything is connected via a plug in Master link splitter box  which has a fixed amount of inputs.  (Video,sound outs I believe).   I would like to add a few more stations to the house namely a Beosound 2000 for the laundry room.   Would I be able to just cut into one of the master link leads running from the Master link splitter box and use a Master link junctions box or do I have to look at other possibilities?    I love the plug n play aspect of the box I am using now but I do understand that I limited in outputs from it.   If B&O only sold a bigger plug in box.
Well ill hopefully the forum can help me out...
thank you
BeoMegaMan
Posts 601
Buy another ML box. Then jump the ML from the previous box. You now have more outputs.
Ah, you know... A little B&O here, a little there
Millemissen
Flensborg, Denmark
Posts 14,680
You can cut the ML cable and connect up to two further 'ML-strings' using the junction box.
I suppose you could connect another ML-splitter-box as well - if you could get hold of one.
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 13 2014 7:49 PM
Ml Junction box
About one million times easier.
Pick up preterminated Ml cables and plug and play.
You could splice... But two ML from the same feed is cumbersome.
ML boxes are available all over the place.
Check the Washington DC store and ask for Aaron. He'll find you one in sure.
striker27
Posts 64
striker27 replied on Sun, Apr 13 2014 10:35 PM
I have the preterminated  cables in the box at present how would I jumper to another box?    I mean that is a great solution and it continues to be plug n play as well.  Which I do prefer just not sure how to do it?   Do I just buy another box for preterminated cables?   If so which connection port do I use from one box to another?
mjmedlo
Posts 922
mjmedlo replied on Mon, Apr 14 2014 12:03 AM
striker27:
All of the ports run in parallel.
They're only labeled for keeping track of your system.
You can purchase a 1 meter ML cable and jump the Signal from one box to the next, using any plug you like in your current Ml box. Then just hook up what you want to the new ML junction box and voila.
You're done!!!!
Millemissen
Flensborg, Denmark
Posts 14,680
Sure the box is the easiest solution - but what if you have to run the cable through a wall to go to a different room Crying
Not everyone wants to drill such a large hole in the wall to get the plug through.
striker27
Posts 64
striker27 replied on Mon, Apr 14 2014 4:28 PM
I have no issues with the hole in the wall for the connector.  I am able to conceal it behind the baseboard moulding.    This is the solution I have been looking for.   The two boxes will work great.  I just have to search out the internet auction sites for a bit and pick one up with some additional cables.    That said would the video slot on the box be open for another link room active or passive as far as audio goes?    That may allow to hold off on additional boxes at least for awhile.   I really thought the master link distribution box was significantly more sophisticated then what it appears to be.     Was not aware about the ability to daisy chain it either.
Great info
Thanks for your info and help.
mjmedlo
Posts 922
mjmedlo replied on Mon, Apr 14 2014 5:00 PM
You are able to use any slot on the ML junction box for anything you want.
The names on them are only for inside the home.
All slots do exactly the same thing.
The video label has no significance as all masterlink connections transfer all information exactly the same.
Good luck!!!
As I said. Try Aaron at the Washington, D.C. Store. I think he still has an Ml junction box available.
striker27:
Great info
Page 1 of 1 (9 items) | RSS
