CONNECTING PROJECTOR BV7-32 mk 3
This post has 5 Replies | 0 Followers
SlyParma
Italy
Posts 127
SlyParma Posted: Mon, Apr 14 2014 10:37 AM
I have a beovision 7-32 mk3 without DVI output. How do I connect it to a projector?
The output you see in the picture (projection) what is it? What qualities do you can give me?
And if I want to connect a Blu-Ray player (with HDMI output) to BV7 as I do (no hdmi inputs)?
And 'possible to add hdmi inputs or outputs DVI to BV7?
Thank you all.
tompa
Posts 64
tompa replied on Wed, Apr 16 2014 6:10 PM
You connect projector to VGA projector output not have the resolution in mind just now but can check if you want
on this tv you have 1 DVI input (more or less the same as HDMI but without sound) and different connector but adapter is availble
if you want more then one HDMI sources you have to have GEFEN Hdmi switch 4-1 if you want it to be controlled by tv also
you need the sound from sources with separate cable from coax out on sources to A1 - A4 on tv if sources only have optical
converter is needed also you maybe have to upgrade your sw (sw minimum 7.7) but sugest latest sw 7.94
SlyParma
Italy
Posts 127
SlyParma replied on Mon, May 12 2014 11:16 AM
Ok thanks. I want to connect to the TV, BluRay and HD satellite receiver with hdmi through Gefen HDMI. But the output to the projector's VGA, how can I get a full HD signal?
Millemissen
Flensborg, Denmark
Posts 14,680
You can't!
Unless you choose to connect the BRP (or the switch with the sources) directly to the projector (HDMI) and run the sound through the BV7
SlyParma
Italy
Posts 127
SlyParma replied on Mon, May 12 2014 1:35 PM
I supposed. In fact, I'm looking for a BV7-40 >mk3 with BeoSystem 3.
Now I take a switch, DVI / HDMI cable to watch TV and DVDs should be fine. For bluray I will do as you said.
SlyParma
Italy
Posts 127
SlyParma replied on Thu, May 15 2014 11:49 AM
The curtain motorized projector, which connects to BV7?
How does it work?
Page 1 of 1 (6 items) | RSS
