Hello,New user here. I was hoping someone might be able to help or point me in the right direction.I have a Beogram 1203 which is in need of new washers for the transport screws. I've done a search and haven't really had any luck in finding where I could get some replacements (or maybe I'm using the wrong syntax to narrow it down). Ideally I'd like to replace all three (one's gone, and another is cracked).Does anyone know where I could find some new/replacement ones or know of a suitable alternative?Any help greatly appreciated!Thanks,Lars
Welcome to Beoworld !
Aren't the screws all metal or is there a plastic washer around the screw head ?Partnumber ?
Thanks!The screws are indeed metal, it is just the washer around the screw head that is plastic. Would a part number for this be documented anywhere? (I didn't get a manual with mine so can't check that).Thanks for any help that can be provided.
I've attached a picture of what one of the plastic washers look like.
