I have an mkIII, type 9760 with D10 panel.
From mkIII all the BV9's have integrated calibration camera's.
The MKIV has a slightly different system3 . These newer system 3's have a different audio board. With a software update these can be upgraded with ALT techonology.
Older system 3's the audio boards can be replaced with a newer audio board.
mkIV and mkV have D11 panels.
Can you tell us more about this:
Beobuddy: These newer system 3's have a different audio board. With a software update these can be upgraded with ALT techonology.
I have an Mk.III model, which I love to death, and the only ALT I know stands for Acoustic Lens Technology, which is the design they use to distribute the sound horizontally 180 degrees in the tweeter below the screen on all BV9 models.
Sorry, you're totally right!
I swapped the ALT for AST!!! The Adaptive Sound Technology.
I cannot recommend buying a beovision 9. During warranty one modul of the beosystem 3 had to be changed. Now after four years I have to replace the plasma display for 2.500 Euros (see thread http://archivedforum2.beoworld.org/forums/t/845.aspx ).
I have a MK II, perhaps the other models are of higher quality. I wish you luck.
In our familiy we have 2 BV9's.
Both without problems and working flawlessly.
Only the integrated BM5 gave some problems with the it's mainboard. But thats' an option not every buyer has.
