Hello,
Anybody tried to connect an MPAV9000 and a BL3500 ?
Does it work?
Can`t work.
MPAV9000 is not an audiosystem, it`s an ML remote with integrated CD player, radio and tape deck.
Stefan
But does it works with an BC2500?
Thanks Stefan
Hi Stefan,
it will work with the BeoCenter 2500 but you need to add a B&O Beolink Converter Type 1611. This converter translates between the BC 2500 and Masterlink.
I have the same here, BC 2500, 1611 and two BeoLab 2000.
The BeoLab 2000 and 3500 are both Masterlink Speakers.
Ralph-Marcus
