Hi Everyone,
I have a Beocenter 7000 running a set of Beovox CX50s, all housed within my full wall shelving unit. My question is this, if i was to add another set of (B&O) speakers what woiuld people recommend? I have been told good things about Beovox S45.2 but unfortunately because the speakers will need to sit within a fixed space (35cm (H) x 30cm (D)) they would be too big. Any other ideas?
Thanks,
Miles
Hi Miles,
I'm not sure the S45.2s are out of the question. They can be used on their sides, in which case the only barrier would be the width of the shelving unit space available. The obvious alternative would be the CX100, but they won't offer the sort of performance imporvement you will get from the S45.2s.
Another option is from a slightly earlier period - the 1702s. These are available in a veneer to match your 7000 and from a period when the quality of B&O woodwork was very good indeed. They sound warmer than the CX range and can be listened to for long periods without listener fatigue. I have used mine with a 7007 - the same amp as your 7000 - very successfully
Cleve
Or you could get a Beovox Cona Sub - will improve the sound out of all recognition!
prod_details
Cheers
Nigel
h1npw:Or you could get a Beovox Cona Sub
//Bo.A long list...
h1npw:Or you could get a Beovox Cona Sub - will improve the sound out of all recognition! prod_details Cheers Nigel
What about hanging P30s or P45s adjacent to the cabinet? Is that an option? I have both, and if you have space for the P45s, they are outstanding. The P30s aren't bad either, but not up to the quality of the S45-2 or P45.
Hi Cleve,
Thanks for this.
The width isnt an issue, so if the S45.2s operate effectifely on their side then i think that is decision made! There are some on ebay currently for £95, is this a fair price?http://www.ebay.co.uk/itm/HIFI-Speakers-Bang-Olufsen-Beovox-S45-2-Vintage-/400688849053?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item5d4aeaa09d#ht_201wt_1161
Thanks again,
I use S45's lying on their sides on a shelf unit. I actually find the sound to be better than when I had the speakers wall mounted in a vertical position, although this is as likely to do with the room acoustics and resonance of the shelf unit as anything else. The original S45's are almost identical to the S45.2 but might be fractionally narrower. The main differences seem to be the resin backs and the fact that they only have one metal trim on the front edge rather than trims front and back.
There is a separate thread discussion on the early S45 and S45.2.
I wouldn't worry about lying these speakers down.... and most of the early Beovox passive speakers (with flat fret panels) had mounts designed for both horizontal or vertical wall mounting (but not the S45 which had a slightly curved/angled fret and a resin back).
Graham
Thanks to everyone for the really usefull advice....I will pm Martin...
