Hope you can help?
My BS Century has developed a fault. When you wave your hand at it nothing happens. If I push the door to the left by a cm it then opens as it should. It will then close smoothly, even if your hand is in the way. As per previous post I have tried cleaning the glass and removing any dust I can see.
Any thing else I can try or does this sound like the sensor has gone?
Toby
