Beomaster 6500 query
lobbmic
Posts 2
lobbmic Posted: Fri, Apr 25 2014 8:38 PM
Hi, can anyone tell me if a Beogram 9500, will work with a Beomaster 6500? The record deck works fine with my very old B&O amp, but when I try it with the 6500 amp I get very little output. I've only just bought the 6500 amp so it could be faulty, but it was advertised as fully operational. The Beomaster radio works fine, plenty of volume/output. Any help will be much appreciated.
Thanks, Mike
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The Beomaster 6500 does not have a built in RIAA pre amp and neither does the Beogram 9500, hence the low output.
You can cure this by using a stand alone pre amp between the two or using a deck with a built in pre amp such as Beogram 3500, 4500, 6500 or 7000.
Regards Graham
Dennis
Denmark
Posts 627
Dennis replied on Fri, Apr 25 2014 9:17 PM
*Cough cough*  Whistle
I have another one, if that has any interest. Smile
/Dennis
lobbmic
Posts 2
lobbmic replied on Thu, May 1 2014 9:59 PM
Thanks for the info. I bought a pre-amp and all is working well. Can you tell me if an IPOD will work with the Beomaster 6500?
Thanks again,
Mike
Steffen
Denmark
Posts 1,408
Steffen replied on Fri, May 2 2014 12:00 AM
lobbmic:
Thanks again,
Mike
Yes it will. Just plug it into the AUX socket. (you'll probably need an adapter)
Page 1 of 1 (5 items) | RSS
