BeoLink 7000 questions
This post has 12 Replies | 2 Followers
Michael
Sweden
Posts 2,578
Michael Posted: Wed, Apr 30 2014 9:35 AM
Hello all,
I have a BeoLink 7000 that won't hold a charge. If I put it on the charger base it will turn on but it won't charge. I guess the battery needs to be replaced. I also saw that a few people have replaced the electroluinescence behind the screen but I´m not sure I need to do that, the screen is still very readable.
Any tips on what I should order for it? I found a few threads on the archived forum where different success was found with different batteries. Is the original batteries still possible to aquire (Sanyo I think?).
 Picture here
badgersurf
Posts 539
badgersurf replied on Wed, Apr 30 2014 10:25 AM
I replaced my battery the other month I got mine from here:
http://www.beovienna.com/products/akkupack-battery-pack-f-beolink-7000
I think it was a sanyo one when it came, but the website says that Sanyo has been purchased by panasonic. They have worked well and was delivered quickly.
As for the screen mine has gone very dim and is only just readable so would like to know if anyone out there can replace the screens (have found the old threads and think this is beyond my capabilities)?
BO
Halmstad, Sweden
Posts 728
BO replied on Wed, Apr 30 2014 11:35 AM
badgersurf:
I bought from the same place. It has to be Ni-Cd batteries. Ni-Mh will not last long (due to the charging caracteristic).
There no gain in aiming for higher capacity then the originals.
//Bo.
A long list...
Michael
Sweden
Posts 2,578
Michael replied on Wed, Apr 30 2014 12:06 PM
badgersurf:
Thanks for the advice. I ordered the same battery now!
The screen on this Beolink 7000 is readable so I won't replace it now but it would be fun to do. I hope you find help to fix it.
Michael
Sweden
Posts 2,578
badgersurf:
Michael
Sweden
Posts 2,578
BO:
badgersurf:
Good to know about the Ni-Cd. I ordered it and will se how it works out later. Thanks!
AceBase
Posts 10
AceBase replied on Tue, Jan 27 2015 5:52 AM
Hi Beo-people,
I also have a BeoLink 7000 with a damaged battery pack. Since Beovienna will not ship to California, I need to find another supplier.
Can I replace the Nickel Cadmium pack with a NiMH pack such as this one?
http://www.all-battery.com/6v2000mahnimhreceiverbatterypackwithtabsforairplane.aspx
If not, does anyone know of a supplier that can ship a replacement pack for the BeoLink to the USA?
Thanks!
-nick
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jan 27 2015 7:31 AM
AceBase:
Yes you can but the charging characteristics are different, it won't hold charge or work for long.  It is best to use the NiCd batteries and not NIMH packs. This has been discussed many times here on Beoworld and people have had all sorts of problems using NIMH packs.
Is it due to an import restriction to the US that BeoVienna won't ship?  If so, you may have to try a 'back door' approach from a friendly member who can buy you one and send it to you.  Just doubles the shipping costs.
Dave.
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jan 27 2015 7:37 AM
I've just looked at BeoViennas eBay page and he does ship to the USA so what is the problem?
Under shipping, you just have to look for 'vereinigte Staaten von Amerika'.
Dave.
leosgonewild
Helsinki, Finland
Posts 2,373
Is anyone experiencing a humming sound from the Beolink 7000 after battery replacement?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Jan 27 2015 9:00 AM
Yes, my Beolink 7000 is also "humming", more a high-pitch whining though.. It is quite normal I guess, it is the 110v supply to the backlight that causes this.
My first BL7000 from 1994 or so, also did it with the original batteries.
/Jacob
AceBase
Posts 10
AceBase replied on Tue, Jan 27 2015 7:13 PM
Hi Dave -- thanks for the suggestion to try the alternate page.
I just added the product to my card, then, when I tried to pay via PayPal, it gave me an error that said they the address was outside the shipping range. I will try again and see what the cost is.
Re NiCad vs. NiMh: Ok, I see there are other threads about this. What I'm finding when I search electronics parts suppliers in the US is that 6-cell AA packs are available for ~ $10. I don't mind having to charge more frequently (as this will mostly sit in the cradle) but I'm worried that a pack like this won't quite fit inside the remote:
http://www.all-battery.com/6v2000mahnimhsidebysiderxreceiverbatterypackswhitecconnector11106.aspx
Any thoughts?
Thanks again for all the help!
-nick
leosgonewild
Helsinki, Finland
Posts 2,373
Weebyx:
/Jacob
Great Smile I am selling my system, and it is nice to be able to say that it is normal instead "it could use a service" Stick out tongue
Page 1 of 1 (13 items) | RSS
